TwinTurbo.NET: Nissan 300ZX forum - Re: couple ?s aboutyour engine pull and installation...
Subject Re: couple ?s aboutyour engine pull and installation...
Posted by MikeH(Twin GT35BB Incon Z) on April 06, 2002 at 8:01 PM
  This message has been viewed 70 times.
In Reply To couple ?s aboutyour engine pull and installation... posted by RaBBiZ on April 06, 2002 at 07:56 PM
Message You can do it in a weekend if you have help. replaced all the gaskets and lines. Too many to list.
I remove the intake manifold first. Hook the chains to the gold side brackets.
Remove the A/C put leave on car. Don't crack open the lines. Remove, the power steering and leave on the car.
Arizona'a most powerful 600HP 15 second Z
More powerful than a stock TT , slower than an NA
Dynoed 515 rwhp and 420 ft.lbs @ 16psi 89 degrees.
533 rwhp and 450 ft. lbs @19 psi and slipping clutch
and heat soaked motor , 85 degrees.
